create flowmon key
create flowmon key key_name
Description
Creates a Flow Monitor key.
Syntax Description
key Specifies the Flow Monitor key.
key_name Specifies the assigned name of the Flow Monitor key. Range is 32 characters.
Default
N/A.
Usage Guidelines
The system will reject any attempt to create a key that already exists.
The following command creates a key with the name 'src-ipv4-addr':
# create flowmon key src-ipv4-addr
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
